I stayed away from this thread ,but feel compelled to wade in. There are few topics that can get more opinions than edge shapes and grind advantages.
First - As moderator, I would suggest that those who don't really know, or are just reciting what they have read somewhere, refrain from technical questions and let those with hands on experience answer the question.On this forum, there are people who deal with single sided grinds daily ( one is the best in the business). Let them answer these questions and the info given will be far more accurate.
Now, from me-
A single bevel, scandi, chisel, or hollow grind ....or any grind.....at 15 degrees is 15 degrees. None is thinner, sharper, or thicker than the other .......at the edge.
The grind mainly controls how thick the blade is behind the edge. A hollow grind removes some of that, but still has a double bevel ( primary and secondary), thus having a moderately strong edge with reduced cutting friction. A flat grind is the same with more behind the edge, and a convex has even more niku ( meat) . All these are just factors of edge impact resistance and cutting friction, and the edge is still the same.
If the blade is a full flat grind or a single sided grind ( chisel), then the edge is nothing but the apex of the triangle formed by the spine and the bevels, as fellhoelter pointed out. The amount of thickness is identical on a full flat or a chisel grind. The only difference between the two is the angle of attack on the edge ( compared to the centerline of the blade) and the fact that one forms an isosceles triangle and the other forms a right triangle. Otherwise a full flat grind and a chisel grind are the same.They both have very thin edge angles and are superb slicers. They both have delicate edges that can be damaged easily and are harder to re-sharpen if damaged. On a knife, they both cut soft things straight. Cutting on hard objects is a different thing, and a chisel grind is only an advantage in woodworking. When used on hard objects like wood chisels and metal gravers there is usually micro-secondary bevel on the backside.
So, why make a chisel grind knife if it is the same as a full flat grind ????
The main advantages of both are in the ability to slice meats and soft things very thin. The chisel grind has the advantage of only needing one side ground to maintain the edge. You sharpen the BACK by laying it flat on the stone and lapping it until the edge is restored.....no angles to figure out and maintain. On a full flat grind you have to do that to both sides. Unless there is some major restoration of the edge needed, you rarely need to lap the bevel side of a chisel grind, beyond a stroke or two to remove the wire.
Some higher end Japanese knives have the back ground as a large diameter hollow grind. This is not a grind to the edge, but serves as a reduction of the amount of metal needed to re-sharpen the knife. The only metal removed in re-sharpening a "hollow back" is a small strip along the edge. Every re-sharpening slowly raises this line, and you can often tell the age and amount of use by how wide the flat area above the edge is on the back. The prime advantage of this is to speed up and simplify re-sharpening.
If you have a large radius platen, you should start a chisel grind knife by doing a wide hollow grind on the back first. If you don't, then just flat grind both sides .
BTW, the bevel side is usually ground 1/2 to 3/4 of the way up the side. It will determine the overall edge angle, so the higher the grind, the sharper the knife. The blade thickness is the other factor that controls the edge angle on these type of knives. A deba is far thicker than a sashimi, and thus can be used for much heavier cutting.Thus, a sashimi blade is thin, chisel ground ( or hollow backed), and super sharp. Doing a chisel grind on a camp knife is just for looks, as there is no reason for it.
The myth that a flat grind will make the slice stick to the blade and a hollow grind will release it is about 99% sales hype. Knife control will handle any slicing situation. Watch a good sushi chef cut thin slices of hirame and you will see how to handle the sticking problems.
On a standard double bevel, you have to try and guess at the angle between the blade and the stone....and maintain it throughout the stroke...for the entire blade edge...on both sides. See what the advantage of a single bevel full flat grind ( chisel grind ) is now?
