- Dec 17, 2001
I have to say I agree 100% with willgoy. Queen D2 just isn't worth the bother, to me. I own several, and only the fixed blade I got came anywhere near "sharp".
-- Sam
-- Sam
I tried using a Lansky system once, and it did not work at all for small blades, like the pen blade and copling blade on a Queen #48, or for that matter the sheepfoot and spey on the #26. The clamp would get in the way of the hone and there was no way to use the system.
Does the DMT aligner system get around that somehow?
Just curious about the problems you've had the the Lanksy? If you look at the clamp there is an area at the end that is cut out, clamp the spine of the smaller knife blade in that recess and you shouldn't have a problem unless the blade is extremely thin or narrow. You might have already tried what I'm suggesting, but many people make the incorrect assumption that you have to clamp the blade way back in the clamp (which you do for large and thick blades) not so for pocket knife blades, hope this helps.
Using this method I could setup in a minute or so, use four different diamond grits (as needed) from X-Coarse to X-Fine and then follow up on the Spyderco Sharpmaker 15 degree setting for a screaming edge in much less time than I could do it freehand.
Does the X-Fine not give you a razor edge?
You need to finish with the SharpMaker?
Straight off the jig I regularly get a edge sharp enough to shave hair.
Neeman,
Need probably has nothing to do with it. I have just come to really like the edge that I get when I finish on ceramic. (I generally just use a Spyderco "Double-Stuff" (which has the 5" x 1" fine and medium ceramic hones epoxied to one another) for most touch-ups.)
If you haven't tried ceramic, I highly recommend adding it to your arsenal.
The classic question "When is sharp sharp enough?"
I find I can maintain a good edge with a couple of passes on my DMT X-Fine
Well, in that case, to use another platitude, sometimes it's best to leave well enough alone. :thumbup:
