As Horesewright said, it chips easily when drilling or cutting. It also breaks easily. They put it on the shelf in FIF just to trap someone into using it as scales. It is not for rough use as a scale. As a spacer on a well made knife it works fine. It sands and [olished easily. Avoid getting it hot.
There are better and worse grades of reconstituted stone. One type is like chips of stone in a resin base. It looks like standard inlay when sanded and finished. I find this works fairly good.
The other types are more like powdered stone mixed with resin and cast into a slab. This type may, or may not, break easily when cutting or drilling. It is also fairly soft.
I suggest using carbide or diamond drills and a jewelers saw with a diamond blade to cut it. A regular jewelers blade will cut it, but you may have to use a couple blades. The best way to cut it is with a small diamond blade lapidary wet-saw.
