I recently added a hinderer eklipse to my collection to complete the "big three": Chris Reeve, Strider, and Hinderer. I bought it used from the JerzeeDevil forum, (my first mistake?), and was initially very happy with it. I then noticed the blade was off center, actually contacting the scale side. This was disturbing, as was search results indicating that this seems to be a common problem, but found that it has a common solution as well. I attempted the standard process for blade centering, and it seemed to help, but when I loosen the pivot to allow the knife to be opened, I can't seem to get it to the point where it can be flipped without losing centering again. If I leave it tight (doesn't open at all, or flips only part way) it's fine, but once I get to the point where it will flip at all, it's already a little off center, and if I loosen it enough to actually get good flipping action, I'm back where I started.
I tried this more than once, getting roughly the same result, then I tried a complete disassembly following a couple youtube videos, cleaning it and lubing it with silicon grease. I reassembled it using the same process as before, and, while my issues now occur at a different timing on the pivot, they are still present.
I don't know how new the knife was before I got it, there was no visible issues or wear and the lockup seems very early, so I will continue to play with it a bit and hope it "wears in" and eventually acts like a knife of this quality should, but I'd love it if someone could give me some advise to assuage this feeling that the "big three" should really be the "big two".
Thanks for reading.
Thanks for reading.
