Gary W. Graley
āImagination is more important than knowledge"
- Mar 2, 1999
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I thought Emerson was still using 154CM.cpm 154, because Ernie says so!!![]()
In my opinion there are different steels that perform better in certain usages and the materials that are being cut. One will excel in one use but not as well in another. I think it is dependent on your personal use and preference and what works best for you.
As for a well rounded/all around knife steel that covers a lot of uses maybe not the top performing in any one category but does well in four important categories, in my opinion that would be Magnacut . It has high toughness, high corrosion resistance, sharpens fairly easily and has good edge retention. I have two knives in Magnacut and they are performing very well as advertised. Mine has held an edge for a good long time and when I finally had to sharpen it didnāt take long or much effort to get a screaming sharp edge. So far Iām impressed.
Ease of sharpening is controlled more by abrasives, heat treatment and sharpening ability of the end user than the name and type of the steel.Well said. To get any agreement on what is the "best all around" thingamajig, there first needs to be some agreement on the important categories that go into consideration.
Then, given that we have measurements for those categories for each thingamajig, there needs to be some agreement on how to combine those measurements into a single "all around" measurement.
If Larrin would be so kind as to give us ratings on ease of sharpening in addition to the other three categories that he has published, we could come up with a reasonable answer.![]()
Your absolutely right, I stand corrected. And I surely wouldnāt argue with you!I thought Emerson was still using 154CM.
Yeah, like a SIG... Don't Drop it...!!!CPM 15V baby
(Not the best all round, just badass)
Interesting, was something supposed to happen?Yeah, like a SIG... Don't Drop it...!!!
Affording and performing are very different when it comes to matters of importance.Easy, 7CR17MOV
Seriously though, my answer will probably differ from others. In my opinion carbon steel such as 1085 or 1095 is probably the best all around due to ease of sharpening, sharpness, edge retention, toughness, etc. at a reasonable cost.
Some people would disagree with me because corrosion resistance is a real issue for some. In their case, I would say 420HC or 440A, for the same reasons as I listed for carbon steel with the exception of excellent corrosion resistance.
You can get better performance (edge retention, etc.) from higher end steels, but usually at higher cost so affordability fits in to the picture when selecting "best all around"
Easy, 7CR17MOV
The rate that a steel will abrade isnāt always a reflection of how well it would preform in slicing, Chopping etc..,I would have an idea of what supersteel it isn't when I go to sharpen!![]()
OK, Now that's Way better then a SIG...! Maybe the CZ of knife steel...!Interesting, was something supposed to happen?
CPM 15V at 67 HRC.
No damage.
Unless you need to āspend bucksā on oil to keep it from rusting.The best steel is the one you can maintain yourself without spending bucks. No blade is going to hold an edge for ever. 1095 is still great stuff along with some of the older stainless steels.
I myself have strayed from the "Ultra Edge" retention steels (Although I still love them), like S90V to more in the M4 range. I think that having a dull knife is better then having a broken in two knife...Unless you need to āspend bucksā on oil to keep it from rusting.
Totally agree. My point is that some of the "supersteels" are a pita to sharpen compared to the "basic/vanilla" steels.The rate that a steel will abrade isnāt always a reflection of how well it would preform in slicing, Chopping etc.
