- Feb 24, 2000
I decided to make a sort of large competition knife out of Aldo's W-2 steel. I started with 1/4"x2" and used the stock removal method.
I have used a lot of Aldo's W-2 steel in 1/8" size and have gotten good hamons.
I have used a torch to heat treat the 1/8" steel, but this knife had a 13 1/2" blade which I felt was too large for the torch to heat so I used my Paragon oven.
My procedure was,
1650 for 20 minutes, then when black quench in Park's 50
1550 for ten minutes, quench in Park's 50 when black.
1450 "
1350 "
1250 "
Then I put Rutlands clay on the blade, let it dry overnight, heated to 1460 for 10 minutes and quenched in Park's 50.
Then I tempered twice two hours at 424 degrees.
When I etched in FeCl and gave a very brief polish, this was the result. The temper line did not come close to how it was clayed. It was clayed exactly the same on both sides of the blade.
The blue tape shows where the clay was.
Those of you with experience with Aldo's W-2 steel. Would you suggest I change the heat treat formula?
When I have heat treated the 1/8" steel I have put a light coat of Brownells ATP-641 over the whole blade. I did not do this with the 1/4" blade.
Any suggestions as to why the hamon turned out the way it did?
My procedure was,
1450 "
1350 "
1250 "
