Anole by Fairall Designs
This is The Anole, and is named after the small lizzard that is often mistakenly called a Chameleon. For those of you familiar with my work, you will notice it's a down sized Chameleon with a stretched out blade and thinned down handle. It also differs in that it has a singular profile, and is not intended to be taken apart and the blade used seperatly as a push knife like it's big brother. It's more of a neck knife or keychain sized utility.
I used Mike Norris Stainless Ladder pattern Damascus to make the blade and annodized Titanium for the structural bridge that is complimented by nugget and whitelip pearl buttons which are trapped within the titanium, and not simply glued. The Frame is Desert Ironwood burl, and beautifully figured. The Kydex sheath will be made as a dual pupose neck knife or keychain confiuration.
Specs:
Blade: Mike Norris Stainless Damascus 58RC .130 thick.
Frame: Desert Ironwood burl.
Bridge: 6AL4V Titanium annodized and nugget engraved w/trapped whitelip pearl buttons.
Pins and screws: 440C pins 58RC 18-8 screws all heat colored.
OAL: 5 1/4"
Cutting edge length 2"
Sheath: Kydex.
Price $350 + shipping including kydex sheath.
Thank you for checking it out.
Brad Fairall
www.fairalldesigns.com
Specs:
OAL: 5 1/4"
Sheath: Kydex.
Brad Fairall
