- Nov 28, 2000
Hello, all.
I believe I read somewhre that the theoretical Busse folder might have a compression lock. My question is, why not make the folder along the lines of a Sebenza? Not a carbon copy, but the basic principle of the Sebenza. Why clutter up the knife with fancy locking mechanisms of any sort, when a simple, basically 3 piece integral lock design might be better? 1/8" thick infi scales with a 3.75" long, 1/8" thick infi blade and dual thumbstuds [or better yet, an opening hole], with a smooth coat finish on the blade- doesn't that sound better? A model of utiitarian infi efficiency, something to perfectly compliment Jerry's cleanly designed fixed blades. Make the clip tip up/down switchable, and I'd be quite happy.
Of course, I'll be in line for a Busse folder of any sort, but it seems to me that a simple, clean and straightforward design would be the most logical path for this knife. Aren't his fixed blades like that? After all, how easy would it be to strip, clean and reassemble some kind of fancy lock folder? What do you do if you lose a part, and you're out in the field someplace? How does one improvise a tiny spring, or whatever the part may be?
Yours in INFInite folder patience,
Frank
Frank
