jstn
- Jun 27, 2012
Bummer. I get mine today. Hopefully I will warm up to it.My Sliverax just arrived. Thoughts:
It's probably a catch and release for me.
- It flips like a Spyderco - not well. It can flip open properly if you wind up, but you gotta think about it. It might break in with use, or with pivot adjustments
- You can close it without the flipper tab hitting your finger. The compression lock tab is long enough that you can press it at the bottom and have enough clearance for the flipper tab to close all the way
- Having your finger slide into the compression lock when flipping doesn't seem to be an issue - everything around the compression lock tab is chamfered nicely
- Ergos are.. odd? It doesn't have a finger choil so my hand is pretty far back on the handle, which means my thumb sits on the compression lock tab. Not super comfy
- (Added) The lock release tab seems to be stiffer than on other compression lock knives I've tried before. It's leaving an indentation on my finger when unlocking the knife. I don't have a PM2 anymore but I don't remember it being as stiff
