Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The Tormek really shines if you have a lot of other things to sharpen besides knives, like chisels or scissors. It does a nice job on scissors with a bit of practice. It's OK for knives, primarily for grinding out damage. Serious re-profiling and re-grinding go faster with a coarse belt on the belt sander, but the Tormek does have the advantage of grinding with no risk of drawing the temper.
One thing they don't tell you about the Tormek, you can freehand flat grind on the side of the wheel...
...back to the tormek leather wheel with green compound for stropping (which it does much slower than a Foley-Belsaw 327 scissor grinder, but quick enough for gun shows usually).
I have been running a knife sharpening business using the Tormek T7 for a few years. I use the standard wheel and a 4k wheel for finishing. I get blades so sharp, you can shave with them. I use that to demonstrate to customers just how sharp my blades turn out.I've been looking into these machines for a couple weeks and wonder what kind of results can be expected for knives.
I have a Triton wet grinder that is a 10" wheel knock-off, it does a good job...but it is a PITA to do different belly geometries on knives. Smaller knives likewise are a pain. Overall it is very slow, and the edge is maybe not as durable since it uses a micro hollow grind.I've been looking into these machines for a couple weeks and wonder what kind of results can be expected for knives.
Just as a follow-up to my previous answer. If a knife isn't too bad it takes me approximately 10 minutes to sharpen both sides and another minute or two on the leather wheel or strop, depending. If the blade is very bad and the wheel has to be graded from 220 to 1000, it takes a few minutes more. In that case I do all the knives on 220 first and when all have been done, I grade the stone to 1000 and do them again. I use a black marker to mark the blades so that I can match how they were mounted in the holder. That little tip makes a world of difference. For really discerning customers I then mount a 4K wheel and do the blades again before stropping. The blades come up so sharp, you can shave with them.I've been looking into these machines for a couple weeks and wonder what kind of results can be expected for knives.
I was intrigued by some comments over on the makers forum that a belt sander (my current speed method) or even dry hand sharpening can heat the edge enough to ruin it. The only way I know to test it with motorized systems is to try the belt sander vs. something like a Tormek. There is not a lot of info here on the Tormek. I'm gonna compare my knife hand sharpened on waterstones and Spyderco ceramics to my belt sander and see if I can tell a difference.
Interesting this comes back up. I’ve basically abandoned sharpening with a belt sander, or at least with a 1x30 cheap sander. I couldn’t do it without over hearing the edge and getting damage is anything more demanding that soft foods prep, soft vegetables and boneless meat. I’ve also modified my freehand sharpening to maximize speed for those times it’s necessary. I do that with water soaked stones mostly to keep the dust down. There is an associate at work that uses a Tormek, but I’ve never tried one.
