- Jun 9, 2021
Asking for advice on the procedure to touch up an existing Schrade pocket knife with jigged derlin covers that are black and brown. I’ve read here that delrin does take to dye very easily and I think I’ve got the jist of it, but my question is do I need to heat up the knife covers a little or do I heat the dye. Being careful not to heat above 180 degrees I think so as not to melt the covers. I have a heat gun but that seems like it could easily overheat so I’m not considering it.
I’ve seen a post here where someone boiled the knife in water for 10 minutes before putting the dye on. Or do you boil the dye itself? Or is there a better method.
My plan is to clean off the glossy acrylic sealer I applied earlier to restore the shine on the UV exposed faded mark side of the knife (pile side looks brand new). Then apply black dye to the jigged portion. Once that is done, then go back and apply dark brown or medium brown to the whole cover especially the edges which have faded a lot from the original. Then, if needed I can buff to a shine or go back to this super hi-shine acrylic sealer with a very light dusting over.
