- May 14, 2012
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
This is philosophy, and not me trying to bash or berate ball bearings in any way. I've considered buying a knife with bearings just because they exist and I think it's interesting. I have a carbon fibre handlebar on my bike for the same reason. No weight savings, no strength increase that I'll ever exploit, BUT IT'S COOL.
Here's where I see a flaw in your argument against me: "Typical design intent is not to design something as strong as possible but rather the best for the intended use".
A knife is a tool used for cutting. You always want the knife as strong as possible for your own safety. How does having ball bearings between the blade and handle make the knife better at cutting? How does it insure the strongest/safest tool?Opening and closing the knife should 1/10 of a second of "use". The real purpose (cutting) should be far longer, and that's where you would normally focus your design efforts for a utilitarian product.
Now, maybe you have a job where you open, slice, close, open, slice, close all day long. THAT might be a good place for the benefit of bearings making that 1/10 of a second as enjoyable as possible (insert your own juvenile humor here). Or, maybe you use the knife like a fidget spinner, or have a butterfly knife. Both good places for silky smooth action.
On a utility knife? Nope. It's antithetical to the whole philosophy of making the best & strongest tool possible.
Going from full tang to partial tang on a fixed blade is a compromise.
Going from fixed to folder is a compromise.
Going from folder to folder with bushings is a compromise.
Going from bushings to bearings is a compromise.
It's just the way it is from a mechanical/engineering standpoint.
Does it really make a difference? For all practical purposes, I'm sure it doesn't. I know for a fact that none of my knives except perhaps one are ever pushed close to their capability and are thus over-designed for my purposes. I'm sure a knife with bearings would be the same. I'll bet most people are the same (witness how many people sell their EDC that looks like it just came out of the box).
But, I'm not talking about what usually happens. I'm talking about the technical reality. Two different worlds.
Washers are a form of bushing
Actually, I think I misspoke. A bushing is a form of bearing for radial loads (like the bushing pivot). A washer should properly be called a thrust bearing. I've just heard the term "bushing" being (evidently incorrectly) used so often to describe washers.So a Crk Sebenza has three bushings then...
I learn something new everyday.
Bearings are an evolution forward from washers, but kinda forward and to the side. Bearings are superior in some ways and inferior in others. They reduce the necessary tolerances on the pivot and in most knives allow the pivot to be fully tightened to the point of no play but have extremely free action because the bearings roll not drag like a washer. They are technically easier to clean, requiring less lubrication and being able to be ran dry and still give decent action, or working fine with oil or grease, where washers usually respond best to grease and oil will work its way out. They are more prone to damage from overtightening and are more vulnerable to debris clogging them up. If ran dry, bearings are capable of rusting, although it is mitigated with ceramic.
Overall I think bearings are an improvement over washers, but they aren't the end all be all of pivot friction reduction technology. There's stuff like Protech and Hogue uses that has a completely washer free design, which is another side evolution. The tech is ever moving forward and innovation will likely eventually render bearings obsolete.
The real improvement we need to talk about because there is no argument to be had on it, and all manufacturers need to get on board with, is ceramic defend balls. Steel balls eventually wear out, ceramic has a nearly indefinite lifespan. The lock will likely wear out before the detent ball. I've had multiple knives have a steel ball that ran flat, and once they do the detent turns to garbage, and only some manufacturers will warrant a worn out detent ball. The cost difference is absolutely negligible, which the ceramic balls are substantially more expensive you're looking at a few cents a piece tops. Spyderco is finally starting to switch to ceramic on some of their CQI knives, and virtually all Chinese knives come with ceramic detents. Get on it!
You missed my pint almost entirely. And that's OK. I at least hope you DID catch that I know even "weakened" tools are rarely used to a point that approaches their mechanical limits.A folding knife is a tool used for cutting, not for prying edge wise against your bearing suspension pivot system. Knives are not made to be as strong as possible (and in fact that's a pursuit that's antithetical to blade geometry), but it's a fact that one of a folding knife's primary functions is to fold open and closed. Properly implemented ball bearings do that easier, if only slightly, than bushings/washers. Meanwhile, they are only potentially an issue in use cases that are distinctly not in the scope of knife use.
I am an actual licensed professional mechanical engineer, and in my circle of friends we have a joke about people that always want to make something stronger and stronger: "What about 3 bolts? Well, what about 4? How about 5? 6?" At a certain point, you no longer need more strength or durability. The "technical reality" is that engineers design things to be as strong as they need to be, because any more so is unnecessary cost, added weight and/or complexity, and at times at odds with with intended use of the item.
If your philosophy really is that a folding knife should be as strong as possible, then I hope you also don't own any frame or liner locks before you start pinpointing ball bearings as an unnecessarily weak link in folding knife design. Ball bearing failure generally won't result in a knife closing on your hand.
Edit: not to discount personal opinion or anything, but just the fact that there are a ton of people here who don't like cold steel's triad lock knives would indicate that strength isn't everything people consider in functional cutting tools. With that being said, I also love those kinds of knives.
But, I'll ask you to clarify "it's a fact that one of a folding knife's primary functions is to fold open and closed".
Making a knife fold is a compromise of mechanical integrity. It adds convenience at the sake of strength. It's a "function" per se, but how is it "primary"? It adds nothing to the cutting ability of the knife. Cutting being the only "true" function of a knife.
Again, I'm talking the "big picture" discussion of the main thread topic.
I DO understand that reality is different (read back to my mention of carbon-fibre handlebars on my bike).
Gimmick to me. Hard(er) for users to maintain, extra moving parts on a device that should follow KISS (to some extent) and add to the cost without adding to the functionality. On the other hand, they add to the fun of the knife. Autos could be called a gimmick too, for the same reasons, but I think most of us here can´t help but grin when we pop open a fast snappy auto. Same goes for flipping open a super smooth ball bearing flipper. At some point a knife starts to transcend its tool roots and becomes art.
Reread my posts and you might get a better understanding.At the risk of sounding rude, are you even trying to make a point? I am perplexed at to what you are trying to convey here, despite you writing that it's just "philosophy". You're stating that you believe you understand how design actually works, but you seemingly contradict that statement by not grasping the concept that something isn't a gimmick if it provides value to people.
The main thread topic is if ball bearing pivots are a marketing gimmick. People have presented definitive reasons why they believe ball bearing pivots offer small but in some cases meaningful improvements for the folding knife world, and your response seems to be: "Folding open and closed isn't something knives need to do, and ball bearing pivots are bad because it's too much of a compromise along the entirely subjective sliding scale I've laid out." I mean, how does anyone even reason with that kind of logic? Clearly people have different use cases for folding knives than I, but I wouldn't go around calling the knives I don't like gimmicky because I don't personally have a use for them.
If a knife was only meant to cut, folding knives would not exist. They only cut when open. But why do they exist? Oh, because they have the additional job of adding safe transport. Diamonds in knives? An expression of art? An expression of wealth? Implying a knife’s job is binary is projecting.More like "unnecessary add-on that doesn't truly enhance the job a knife should do", which is to CUT.
A knife exists to cut, not "provide safe transport" or fold. If it existed to provide safe transport or fold, there would be no need to sharpen the blade or even have a blade.If a knife was only meant to cut, folding knives would not exist. They only cut when open. But why do they exist? Oh, because they have the additional job of adding safe transport. Diamonds in knives? An expression of art? An expression of wealth? Implying a knife’s job is binary is projecting.
I love ball bearing systems. Some of my favorite knives, the ones that have the most satisfying 'feel' to their action, had ball bearings, like the Swish or Reate Baby machine.I have owned a lot of folders and most of them used some type of washer system for smooth opening action. I bought a Topps Mini Scandi folder and it's the first knife I've owned that has bearings. I've used it for very light use for about a year and now there is a lot of play in the blade even though the screws are as tight as they should be. Now I'm thinking I need to take it apart and replace the bearings to fix it.
In the past I have just taken knives apart and cleaned and oiled them fairly easily and the whole bearing thing seems like a huge pain to be honest. Are bearings just a marketing gimmick? To me it seems like more work and less durability for little noticeable benefit. Would love to hear other opinions.
*Philsophizing*
From a mechanical standpoint, the strongest knife will be a one-piece.
If two piece-folder, you want to make it as much like a one-piece as possible, which means having the handle and blade locked together as tightly as possible.
Using a washer means the contact point between the parts is the surface area of that washer x2. Which is less surface contact than if there were no washer/bushing.
Using ball bearings means the contact point(s) between blade and handle are now 100x less than they would be with a washer/bushing, and 500x less than if there were no washer/bushing. I completely made those numbers up.
Since a folding knife is for cutting, and we want the "bond" between blade and handle to be as strong as possible, how does reducing the contact patch between blade and handle add a benefit?
