Sorry, I don't have any pics of mine yet but I can give you some info: It's around 5.5" OAL, roughly 2.25" BL, and 1/4" thick (3/8" would have been preferable for the purposes of this knife, IMO...see my comments below*). The knife is skeletonized; that is, the handle is very similar to the PR concept, with no slabs or handle material, just large holes, intended to lighten the knife, I guess. The blade is very much different from a PR blade shape, however. It is not a drop point or a clip point; the spine is straight--if anything, the spine may even curve upwards slightly toward the tip, if my eyes aren't deceiving me. The blade has a very nice contour; the amount of belly is just right for this type of knife, IMO. Mine came with the typical Busse hair-popping edge, except around the belly, where it is slightly duller. It will still shave marginally, but nothing like the standard Busse edge which almost SCARES hair off your arm when it gets close. Nevertheless, it's plenty sharp. The edge grind is symmetrical, and the primary grind is flat and goes all the way to the spine in typical Busse tradition. I noticed a few niggles--the crinkle coating didn't totally coat the inside of one of the holes, and the top of the handle was not ground exactly perpendicular to the sides, but none of that is a show stopper. Busse makes the best knives, period, and I will continue to buy new models from them. I only wish they would pay more attention to detail and hire someone in the QC department who is a total fanatic. That would ROCK. But even so, as they are now and if they never get any better with their QC, they still put out the best knives in the industry, far ahead of their competition.
The AS is a little heavy for a neck knife to me, but hey, it's INFI! I've never handled a PR, but from the pics I've seen, I would venture to guess that the AS is a bit lighter than the PR. I would also like to rave about the handle contours. This is a hard thing to please people on because of the parameters you must work within when designing a neck knife handle (i.e., it must be as short as possible, and this usually means you will have to sacrifice a full, comfortable grip to achieve maximum concealability), so taking that into consideration, Busse pulled off a minor design miracle. The handle is only long enough for 3 fingers, but man, what a solid, sure grip it offers those 3 fingers! The finger grooves are the perfect size and depth, at least for me, and I guess I have average sized hands for a guy. There is also a detent just aft of the blade spine, making a very comfortable thumb rest, which helps you improve your grip on this small knife tremendously.
All in all, I'd rate this knife very highly in design, and a super bargain also, particularly for those who want to experience the fantastic abilities of INFI that they've heard so much about, but have never been able to afford a Busse thus far. If you're looking for a BOMB PROOF neck knife that will serve you, your descendents, and that 25th century archeologist who finds it while digging up your remains without fail, this is what you've been looking for.
Kudos to Jerry and the Busse team. Another model to be proud of. Yes, I'd buy another (as soon as I have at least one of all the other models, though). Keep those new models coming, guys.
BTW, many thanks go out to Dave Roberson, who got this out to me fast, and for taking care of that minor problem for me. I think I shall have a drink in his honor tonight--and no cheap stuff, either!
*The only benefit of extra thickness is for prying, and almost ANYTHING lying around nearby would make a better improvised prybar than a 5.5" knife, and the extra weight of 1/4" is unnecessary and uncomfortable to wear around the neck...it IS meant to be a neck knife, after all, not a mini prybar on a necklace. Besides, aren't the LMS' more desirable to most of us than the regular 1/4" MS'? Anyway, just some opinionated ramblings from an armchair expert, and worth exactly what you paid for it.
[This message has been edited by X-Head (edited 04-20-2001).]
