- Jul 7, 2002
HEYAHHHHHHHHHHHHHH at last easy RAZOR SHARP khukri"s
i have spent the last3-4 days slowly getting my khuks blunter .
i tried several ways even bought a rubber sided sanding block,2 differant dowels wetand dry differant grits ect, to no avail.
THEN AT LAST. i went down to my local hardware store to look for a last ditch effort to find somethin to sharpen these khuks.after about 10 mins BINGO i spotted a little pen like object amongst all the gadgets and gizmos,its called EZE-LAP from carson city. nv.
well i paid my $26 australian a little dubiously .about $13USA and headed home.right out came khuk no one 15inch ang khola, i held the kuke with the sharp side away from me and started experimenting, stroking straight across and then down long ways being very carfull to not slip onto the blade. well to cut a long story short i found the best way was to just do a 3-inch section at a time blade held with sharp away from me then proceeded slowly figure of eight stroking at a nice flat angle to the blade, when i say flat i mean laying the flat section of the sharpener onto the blade as close to the original angle allready there,then backwards and forwards in a figure of 8 like stirring a cup of coffee sort of, about 7 figures of 8 then move up the blade to next 3inch section and same again till you finish at the point of the blade, then swap hands turn blade over do same to the other side. then test edge gently with thumb, finish of with a couple smooth slow strokes to each side of the blade, wipe with cloth oil and bingo ready to put away. or use. what a great little gadget. it is semi round with a groove on the top for sharpening hooks ect, and on the bottom its flat the flat side is what you lay on the blade with your index finger on top to steady . and just go slow so you have total control. AS I SAID I COULDANT SHARPEN ANYTHING.this little beuty makes it easy, and you can have your blade as sharp as you want.and whats more it clips nicely on your pocket or on the side of your scabbard frog. NOW THE EXPERTS HERE ARE GONNA BE SHAKIN THERE HEADS WITH HORROR, BUT IT GETS EM NICE AN SHARP AS MY ARM CAN TESTIFY I HAVE ONE VERY BALD FOREARM AFTER SHARPENING 7 KHUKS AND A KAGNESS KATNE AND ALL THERE KARDAS. plus it took me approx 60 mins to do the lot once i got the hang of it. good luck just go sloww till you get the hang of it.
