Brian C -
Listen carefully ... why do we NOT dry-fire a rimfire rifle or pistol? Because the firing pin will hit the rim of the chamber and will deform it slightly so that the cartridge cases stick. Why do we NOT beat on the bottom of a tomahawk eye with the hardened face of a hammer? Because the eye area of the hawk head is SOFTER than the hammer, and will deform, and bulge into the eye, and you won't get a handle to fit right until you re-shape the damaged area. If you have to do it that way, use a hardwood or brass drift.
Enough said.
Cliff -
Suggest you try your "wide surface" with a hawk having an upswept upper edge ... if you don't strike within about an inch and a half of the edge of the block you've just hit the upper blade between eye and point and have a very non-perpendicular skewed impact that doesn't help the handle fitting. If you're off by an inch, the corner of the handle hits the edge of this "big target" and you likely chip off a chunk of the handle. Especially when you are striking from shoulder height (you're right on that one) trying to equal by more primitive methods the degree of force effortlessly available from a $30 2-ton arbor press so that when the handle is finally "in" it is going to stay "in" virtually forever - without wedges. Now try this when you've just done about 12 hawks, it's late at night, and your tail is dragging.
I'm not as clumsy as you apparently think I am - just smart enough to figure out a way to dependably set handles without ANY chance of marring a precision ground hawk head or chipping a corner off a handle that cost me money and probably already had a couple of hours of shop time invested in it. I learn from unhappy experiences ... and when possible, try to keep others from making the same mistakes.
TWO HAWKS
http://www.2hawks.net
Enough said.
Cliff -
Now if you mean that you miss the target completely and smash the handle off something else, well yes I didn't address that because quite frankly if you do that you really should not be using a tomahawk as you don't have the control to use it safely.
TWO HAWKS
