- Mar 13, 2012
I guess something I'm curious to know is are there any high end steels that will take an edge as easily as aus8 or 8cr13mov? As mentioned I spent a ton of time on some hard vg10 and I know my brother has spent quite a long time sharpening ZT s30v. I don't mind sharpening more often if it only takes a few minutes.
In fairness I guess I should clarify I was sharpening out a chip on the vg10 which took quite some time.
I do own the CS Recon folder (I think 09 model) that of course is Aus8 - it is fine but with that comes with the rolling or chipping if you thin out the geometry of the edge. That is what I have found on my end at least.
I have used the alphabet steels on two occasions. No need to mention the knives or companies because it doesn't matter.
The lowest grade of steel I use in any of my edc pieces would be Sandvik. And I pause to even call Sandvik 14C28N "the lowest" ...that is usually the level of steels you read from bottom to top.
IMO a properly done Sandvik with a proper edge geometry that wasn't labeled or known to the user - the difference would not be known between that or a say 35VN or S35V. Like what was said earlier - this era IMO will be looked back on as the beginning of the 'Golden Era' of steel.
Another great steel that I don't hear mentioned much is Niolox. The Niolox on the HEST TripleBlack T3 is just incredible and has moved up my list to my favorite...at least with this particular knife - no chipping - no rolling of any kind.
OK I am done.
