- Jan 26, 2002
Since I may have the first of these beasts--Plain Kesar-made YCS ordered during the Pala sale and received the end of Feb., and which looks just like these recent fancy ones, I've been interested in the recent reports and had to go out and chop some more.
You guessed it from the subject title....
After several delightful strokes into a clear section of a partially dried loquat log, using mostly forearm strokes--no big windup--something felt or sounded funny. Don't know which. Anyway, about 5" from the tip, there was a single large deformation in the edge. I immediately understood the lasagna noodle description. The deformation was almost 1/4" wide,extending inward from the edge about 3/16". Maximum displacement from the rest of the edge was close to 3/32". I looked at this in shock, and wondered what to do. I couldn't believe the metal hadn't torn. I held the bevel flat against the sawn-off end of the log and using the sawn end of a 3" diameter, 14" length of the same wood as a hammer disturbingly easily worked the metal back to 80% original in a few not particularly hard whacks. A couple light blows from a hammer, again using the wood as an anvil, took it further, but I went back to the little log as it didn't leave marks. Not quite in line yet, but that seemed too easy. The log is lying on the ground, so my "anvil face" is vertical, darned awkward placement, so I really didn't apply any real force. I'm sure I could easily finish the job just using the wood especially if I dig under the brush pile and use the stump so I can hammer vertically. This is hard wood, but I've chopped on it with all my khuks after sharpening them, including the Kesar YCS. Didn't chop a lot with the YCS though, I was seduced by the polish, and have also been oiling the handle. I grabbed my UBE (Bura) and really got going on the log in the same spot. No problem.
A new Nicholson single cut "Black Diamond" file does sound a little higher pitched when used at the sweet spot, but seems to get a good bite everywhere on the blade. I also used the file on my AK, my inexperienced senses don't detect any large difference in the files action on the two blades. I think there was less grab in the sweet spot of the AK. I know it was more difficult to sharpen the AK there. The AK was also made by Kesar, but I've used it to chop a bunch of 3" diameter knots off of the same log with no problems. I haven't tried the file on the Bura which I've recently stropped, but my curiosity is building. Those who can confidently check the edge hardness may wish to do so before using a Kesar YCS.
My opinion on the Kesar YCS has changed to khuk looks very pretty, but not very useful. Dunno if initial hardening or overgrinding to get thin is the root cause, but something seems awry. Too bad, it felt really nice to use, too. But at least this didn't happen when I counted on it, or was bragging about it!
Comments???
Comments???
