- Feb 24, 2016
I believe that I posted some concerns on ball bearing pivots in the thread the op mentioned as well, and like the op I also bought a ball bearing pivot knife to use, test and find my own answers. I picked the ZT 0909 for my test mule.
So what are my completely unscientific observations after several months of using it for hard, dirty ranch work?
Ball bearings seem to be just fine for me on a work knife.
They do get gunk in them easier. It's also quicker and easier to get that gunk back out, so to me that's a wash, pun intended. I do still believe that something like PB washers would likely be stronger in some loads, all other things being equal, than ball bearings due to spreading the load out over a much greater surface area. It also appears to me that this added strength is completely academic since the ball bearings have handled everything I've asked of them so far with absolutely no problems whatsoever.
My not so expert opinion on the issue? If you like the knife and it's from a quality manufacturer, don't worry about the pivot. Buy the knife and use it. The pivot will be just fine.
I will say that I do have a preferred pivot system for some of the sorts of extreme situations mentioned earlier in the thread. Things like no access to running water or any way to clean the pivot for a significant amount of time, wilderness survival, wood processing, an impending apocalypse, etc, where ball bearing pivots may theoretically not be up to the task. If those types of scenarios are really a concern for you when making your knife choices, I'd personally recommend sticking with the following pivot style.
