Can you add a tiny drop of bleach to keep mildew away?
Borax might be more effective but I have tried neither.
I recommend purchasing from a reputable knife dealer other than Amazon
Does this apply to products sold by Amazon directly, or only third party sales?
You can tell because it's right there in the price.Hello guys,
I just received a knife which I bought at Amazon for $14: https://www.amazon.com/Damascus-Kni...child=1&qid=1588907359&sr=8-1&srs=20640497011
They say: 【Japanese 67 Layers VG-10 Stainless Damascus Steel】VG-10 – Made up of Carbon: .95 – 1.05%, Vanadium: .10 - .30%, Chromium: 16.10 – 18.50%, Molybdenum: .90 – 1.20%, Cobalt: 1.30 – 1.50%, Manganese: .50%, Phosphorus: .03% This is the most popular stainless steels amongst Japanese knife makers. While other damascus knifes only have fewer Chromium(14.05-16.50) and No Cobalt.
It looks like it is a $14 knife in terms of hammered finish, handle workmanship and accuracy etc. However, the blade is really sharp for a factory sharpen knife. It cuts paper, shaves etc. I bought it out of curiosity because of the price. I also wanted a knife to practice my sharpen skills. But after testing the knife it is effeminately cuts better than anything that I have, so I feel some reservation to practice on it before it gets dull. Nevertheless, my question is about posibility of it to be VG10. I guess no way it can be VG10 since material should be more then the price if we count the handle, the box it came in, the shipment, fees etc. If you look at the amazon picture at the link above you may see that the lines from suppose layers of steel look too ornamental. Bottom line: does it look like VG10?
The bleach will turn into salts pretty quickly.Can you add a tiny drop of bleach to keep mildew away?
I never got good results using it as a splash and go and although I rarely keep the Hayabusa submerged for days at a time like some other stones it has been soaked for many hours with no crazing or cracking.The Hayabusa is my only finishing bench stone and I have been treating it as a splash-and-go. You haven't seen any cracking/crazing problems on the Hayabusa with extended soaking?
Does 10Cr15MoV look damaskus? Is it OK steel?some sellers from china label 10Cr15MoV as VG-10.
The type of steel is irrelevant to any pattern you see.The pattern there was way different and not as curvy as this knife. Are there signs how to spot real or fake VG10?
Hey Wade,
I do sauerkraut about once a month! Do you know that you may do sauerkraut without salt at all. The fermentation goes even faster, however it will get too sour too soon.and I am tired of cleaning the mess I leave every time around of cabbage and carrot shavings - LOL.
That is why I want really sharp blades for a board which can drop all cuts in a bucket under it. The problem is to find the blades thus I could sharpen them razor sharp, and they have to be sturdy. I am sure that a self-made edge-pro (i did mine of two pieces of 2x4 boards and a foot square piece of oak step ) will do wonder for the blades provided that I could find the blanks.
Thank you Old Biker,How about planer blades, for a 12 inch or 13 inch planer? They will be about 1/2 inch wide by 1/16 inch thick.
Or do an internet search for knife making supplies. There are a number of companies out there that sell knife making steel. There is a lot of choice in kind of steel and size of stock. But it probably isn't heat treated. So You would need to send it to a professional heat treater after you did your rough grinding and drilling.
O.B.
I did look at Home Depot at a set of spare blade for electric planner. They were too flexible. I found that there are companies like NJ Steel Baron who sell steel planks. They have in stock for $7.35 a piece 12"x0.125"x1" of AEB-L steel. I am not sure if it is what I need? I also have not a clue how I will have to heat treat it? I am not sure if it is the right price and how many blades do I need: 2, 3 or 4? I think for my project I would rather look for a steel which may not be very hard but very easy to sharpen to razor sharpness, since cabbage does not suppose to dull the blades fast.
The grey & white are my favorites for such uses, used on a paddle-type strop of denim-over-wood.
Wade,
Do you sharpen your board's blades and how sharp they are? What do you use to shred carrots for sauerkraut? I use regular food-processor.
