- Mar 8, 2008
A really interesting piece of work! A lot like a combination of a chef's knife and a Chinese-style slicing cleaver. The broad blade is a flat grind of true taper, which makes the angle of the primary grind very narrow. These makes the blade exceptionally thin as it approaches the cutting edge, and when combined with the continuous curvature and deep belly of the blade allows for a very long and almost circular cutting stroke. I can still use the point to a reasonable degree (if I was to need anything more nimble I usually use a paring knife anyhow) and I can making push cuts with the tip as well. It tracks very nicely through the cut for very flat slices, and I can carry a whole cubed chicken beast on the flat of the blade when I go to transfer it to the pan. The handle is almost stupidly comfortable, as well. Seems to hold a very good edge so far!
