- Jun 1, 2017
I came up with a concept for a knife that has a detachable firesteel (For the purposes of this thread, a firesteel is a piece of carbon steel that produces "cool sparks" when struck with a hard rock such as flint or quartz, not the modern ferro rods). While, yes, I could just use the back of the knife, that is somewhat difficult, dangerous, and ruins the knife over time. Last summer I ordered a custom knife made that had a full hidden tang and a crossguard; the user can unscrew the end cap, pull out the handle and guard, and use the guard as a firesteel. The concept works, but you need pliers in order to tighten the end cap enough to keep the guard from wobbling.
I came up with another plan involving a full tang knife with a small hollow compartment that holds a firesteel (along with a magnet to keep the parts from rattling). My one problem is that to access the firesteel I need to remove the scales, which requires an allen key or screwdriver, both of which are one more item to carry/loose. With my current knife I can at least access the firesteel without tools, or even without removing it (may damage the handle), but this way, my only option will be to use the back of the knife (or whittle a disposable allen wrench).
So my question is, does anyone know of a way to make knife scales that can be removed and replaced without any tools but your hands, or easily made tools such as sharp sticks? Please, nothing complex, expensive, or protruding. Ergonomics > Aesthetics.
