When working with MOP make sure you wear a rspirator, it can do nasty things to your lungs. As far as belts and such use fresh belts, but not too aggressive, maybe 220 otherwise the pearl can fracture on the edges when being profiled. To polish it go through the normal range of belts that you wold use to polish wood, start with 220 up to 400 and then buff. When drilling holes it is a good idea to make sure you back up the pearl so the drill dosen't break through and fracture it, wood works well. I also put a few drops of water on the spot where I am going to drill to help remove material and keep the drill from getting hot.
Chuck
