- Nov 28, 2014
Matt,
Based on the work you've been showing recently, it looks like you've gotten past the impatience and laziness.
I've been called stubborn so it took a while!
Matt,
Also, the angle isn't constant down the blade. The thickness reduces due to distal taper and the grind height varies as the blade tapers in width. This makes a continuously changing primary angle. If you worked off a fixed jig and filed/ground the angle at an exact number ( say 7.1°) the edge would be wide and flat at the tip and go to a zero edge at the plunge.
I often say that a new maker who builds a filing jig to make his blades is like a guy who goes to a nude beach with binoculars. He may see a close up of a cutie in the buff, but if he would set the binoculars aside, he would see the whole beach full of cuties. The jig just limits you to a small range of only one thing.
I don't think we're talking about the same things.First, most every knife is better with a distal taper. That is part of the filing/grinding in shaping the blade. More on that is a moment.
Second, if the tip rises on a bar of steel with no distal taper, as in your photo, the angle will have to increase or the edge will get wider as the tip rises. You do this change in angle by pushing harder as you file or taking more strokes in that area, but the angle is changing. If you doubt this, lets do the math:
The steel is 1/8" thick and there is no distal taper. The blade is 1" high and the tip tapers up. For the point of this example, lets assume a FFG bevel that goes to a zero edge. Measuring the angle at the point where the tip is 1/2" wide - the angle at that spot is 14.2°. At the 1" wide places - the angle is 7.1°. You don't see this difference, and really don't notice it as you grind/file/sand ... but it is there.
Back to distal taper:
To keep the edge angle the same as the tip rises, you add distal taper as the tip rises. If the change in taper ( thickness) is the same proportion to the change in height, then the angle stays constant. .. it is simple math
Many blades seem not to have a distal taper, but if you look close or measure with a micrometer, you will see that the blade gets thinner as it approaches the tip.
Only under the condition that the thickness of spine on tip remains the same , 1/8" thick..........Which is impossible, because from the start of curve the tip of the knife is taper ......
KD Knifeworks, Don't worry about screwing up. You can't bake a cake without making a mess or something like that. I have a pile of failed knife blades...I save them to remind me that I am not a naturally gifted artist. There are no shortcuts to knife making that I know of. Here's my opinion: grind a blade..,if if it looks bad then try to save it because it is now free practice. Then grind another and so on till you make one that looks good and finish it and pretend you are as good a knife maker as the other guys who do the same thing. Jigs don't work for me and most good knife makers do not rely on them but I do think a small work rest for the grinding wheel helps you do better work. I don't care how long you do this but some days things are going to go south...man up and take a deep breath and go do something else for the rest of the day. If it was too easy who would take pride in doing it? Have fun...be happy...make something nice. Larry[/QUOTE
Do not take this personally, it is not meant as criticism. Its meant as encouragement for new guys FR.
IMHO; having a pile of failed knife blades, does not a knife maker make. Not having a pile of failed blades is probably a better indication of mastery.
There are hundreds of good and accomplished knife makers on this forum that use jigs and fixtures of all types. The ability to think outside the box is the best indicator of a new knife makers future success, more so than their innate ability.
I've worked with many different makers over the last 18 years and what is most interesting is, each has their own process to turning out the final product. The end results may look similar but each craftsman has his or her own approach, its because each of us learns differently. Kinetic, auditory or visual.
Decades of working with my hands has taught me to, "not" work myself into a corner, with my thinking, but instead to look at all the possibilities. This is how each of us finds our own way in making what we make.
Regards, Fred
With a grinder or a file one has to define where is the edge center line and where to bring the grind line up to the spine. The file or the belt have to remove what's in between, blending all the variations in pleasant way... A jig can only complicate things; filework actually prevents screwups since it is very controllable.
