What do I look for for use with glasses? (severe astigmatism, progressive lenses).
Also, I want a small pair primarily to use at the fights I always go to see (MMA and boxing in a ring). The ring is always well lit and looking from dark to light. I don't think I care about field of view, because the action all takes place in a small (ring size) area. Anything in particular to look for?
Probably your best bet is to find someone with binoculars and try them out at a fight....
Generally 8x is the most recommended general usage power/magnification. Most people can manage to hold them steadily.
Looking from dark to bright area could present some problems depending on how bright and contrasty the scene is - it may cause some problems on internal reflections - probably the sort of problems I had with "against the light" tests.
If you intend to use the binos with glasses on, then look for good eye relief as Cougar Allen above - with your glasses off - I'm afraid that would have to be by trial and error - perhaps make a shortlist of binos and go try them out in a shop first - but know what to look for and if possible have a "benchmark" pair to compare to.....
Having said all that the Nikon Sportstar 8x25 at about $20 just seems too good a bargain to pass up - that is if our BladeForum members haven't already bought them all up
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://unknownvt.multiply.com/photos
