Birch bark dagger
Hello guys , a dagger that I finished recently. The shape is loosely based on the FS dagger. The end cap is threaded tube , used as a nut to fix the blackwood piece. The end of the tube is filled with stainless wires and resin to form a mosaic pin.
Steel – Becut 56-58 HRC.
OAL - 238mm (~9.3").
Blade 124x22x4.5mm (~4.9"x0.9''x0.18'') flat grind with secondary bevel.
Blade finish - P800.
Handle – birch bark, African blackwood and bronze.
Leather sheath with wooden inlay .
Weight with/without sheath – 98/143 gr.
http://media.snimka.bg/s1/6221/038685266.jpg?r=0
More pics
Nice looking dagger.. I like the combination of the handle materials. Did you turn the handle on a wood lathe?
Thanks , no I didn't use lathe. First I shaped the blackwood parts with drill and sanding and then after I stacked the bark I grinded it by hand .
