- Dec 10, 2008
Here is a brief review of my BK2 Companion. I was finally able to get it out of the post office. Out of the box like the 1095 Carbon steel it is made of the BK2 Companion is an unpretentious nothing fancy quarter inch thick at the spine drop point blade with with a single plain jane flat bevel. Fit and finish is decent with a slight ding on the spine. It feels substantial well balanced but not at all heavy. The BK2 has a decent factory edge I washed it off and sliced some rib roast not paper thin but good enough for a french dip. Touching up the blade some should get me those paper thin slices. It handled well in my hand. I stabbed a phone book a bit over 2.25 inches deep without effort. Out the door is a four plus inch diameter branch the wind and snow knocked down. I was able to chop it in half and remove the bark in under a minute with no effort and no effect on the edge or finish. Than off to the task at hand which was clearing my driveway so I could get a good ice free run through water over my driveway. I used my Companion on some ice four to six inches the shovel could not break up. The BK2 did so with no problem. Again without any noticeable effect on the edge or the finish.
Not an extensive torture test more like an average use day, well not really I do not use my EDC Kershaw to chop up branches or hack through ice. The BK2 impressed me as exactly what it appears to be a working mans knife more than capable doing whatever it is called upon to do.
I bought the BK2 to pair up with Kershaw Outcast (because the Becker Brute is no longer available) as a general use camp knives. So folks would leave my knives alone. Instead it may end up on my hip, my EDC camp knife (it will be less cumbersome than my MercWorx Equatorian) and into my trunk as my go to car knife when I am not off in the woods. I may make a custom wood handle for it and have a leather sheath made if I opt to EDC when I am out and about doing chores with having that tactical mall ninja look
Ethan
A couple of questions if I may. Promise none about the Brute.
First off is the BK2 made of 1095 Carbon steel or Ka_Bars 1095 Cro-Van Steel. I would guess that 1095 Carbon would lack Chromiumand Vanadium What performance differences can I expect?
As 1095 is not stainless steel should I be concerned about the tang? Should I remove the handles periodically and oil or grease the tang?
What do you think about convexing the blade on the BK2 Companion? I am doing it on the Kershaw Outcast as the blade edge was far to steep for a general purpose knife. It was about 40-45 degrees I am reprofiling it to 30 degrees and than I will convex it. OMG D2 steel is brutal I have over 15 hours reprofiling the edge and have completely worn out my Gatco course stone. Anyway the BK2 does not look like it needs to be reprofiled and 1095 won't be as hard to work with. So do you think that convexing the BK2 Companion it will be worth the effort?
Last, Mr Becker thank you very much for producing affordable good quality working mans knives. The BK2 Companion is a well made, well designed knife made from good steel that can do everything it is intended to that we average working stiffs can actually afford to use it without cringing for fear that it will get scratched, scraped, broken or stolen. A true working knife for the workingman
Ethan
