I find it funny that so many people are doubting the OPs knowledge and ability to reharden the blades, this is not magic, nor is it only big companies that can pull it off, its the opposite, everything is known, its just that the big companies are trying to save costs by underhardening the steels.
I like what I have read at least.
His method is simple, and its the only right method, aim for max hardness (or choose another alloy), do everything as quick as possible, quench as as aggressive as possible without the blade cracking, no wait periods, keep the process going, cryo at the right time, quenching after tempering, its all the way it "should" be done. To get the perfect heat treat you can only do one or a few blades at a time, even in the same kiln the temps will vary too much from place to place so you cannot get an optimal HT all over, this is why mass produced blades suck, you need to work fast and you can only do a few at a time to be able to get them all good.
People actually doubt it works this way?
When austenizing stainless at 100 degrees more you burn like twice the power, this is why everything is so soft from the factory. They try to save money.
I would not hesistate to send out my knives to this guy, even if he´s drunk it would be better than factory.
With experience comes wisdom, the wisdom to read between the lines or TTT charts in this case, the guy probably knows exactly what will happen if he alters the mill recommended HT. And so does a lot of people, almost no steels are made for knives and all the suggested HTs are for non knife objects. Stamps, tool holders, dies or whatever, but not knives.
cotdt and Phil Wilson, I wish you all good luck, you 2 seem to be some of people with the most knowledge in this business, and work good stable equipment, or maybe some of the few that tries to do this as good as possible, no cutting corners.
I´d rather have AUS6 or 420hc made by you than S30V by Benchmade. :foot:
It was a good thread. And now its back.
