Cobalt
- Dec 23, 1998
This test was performed by me and a few friends. The Body Armor used was Type IIA, meaning that it will stop up to a .357 mag. It will NOT stop rifle ammo or armor piercing ammo. In any case, the stabbing was done by hand while the vest hung free.
There were several levels of penetration.
The first was no penetration;
Buck Intrepid
Ontario Tanto(10 inch, 1/4 inch thick blade)
Mission MPK
Busse BM
Busse Steel Heart II
BK&T Brute
TOPs Anaconda
The second was barely penetrated into one side with tip barely poking through;
Recon Scout
Trail master
Ontario Frontiersman
Black Jack 1-7
CS SRK
CS Recon Tanto
The third was that the knife went through the first and into the second or back side of the vest but did not poke through;
Buck NightHawk
SOG Tech II(Same as Seal 2000)
Timberline Specwar
Lightfoot Talonite Pit Bull
the fourth was that the blade went through the first side and through the second side with only the tip poking through;
Gerber Bowie 15 inch oal, 0.3 inch thick
The fifthwas that the knife penetrated both sides with the tip sticking out of the vest between half and a full inch;
Katz Alley Cat Fighter
Reeves Project II
The sixth was that the knife went through the vest like a hot knife through butter:
Lightfoot stellite 6K Predator tanto--This knife went through the vest like if it wasn't even there.
Randall #14 SS- Easily went through both sides, but I felt more drag on the blade than with the predator.
Ontario Hells Bells went through about like the Randall, penetrating so far that the stupid little cho would get stuck in the material causing snagging every time. I didn't expect this level of penetration after seeing the Frontiersman, but after looking at the blade more closely it makes sense.
Results will vary from person to person, but three average strength men all ended up with the same results.
There is no doubt that the thinner profiles penetrated better, except in the case of the Predator and the Randall. The predator is a fairly thick piece all the way to the tip and I didn't expect much after seeing how the Timberline Specwar handled. Boy was I wrong.
The Randall behaved more impresively than I expected also, go figure.
Believe it or not many knives did not penetrate well. The very blunt knives behaved as expected. The Buck Intrepid really surprised me as it just "thudded" into the vest and did not penetrate at all. Same went for the Ontario Tanto.
This may or may not surprise some of you. The Gerber Bowie surprised me. I didn't think it would go in at all after seeing how the Busse's did, but it does have a better profile.
I left a few knives out because I cannot find them right now, when I do, I'll add them to the list.
Buck Intrepid
Mission MPK
Busse BM
BK&T Brute
TOPs Anaconda
Recon Scout
Trail master
Black Jack 1-7
CS SRK
CS Recon Tanto
Buck NightHawk
Timberline Specwar
Reeves Project II
