Love the braid.
Only use mono for leaders.
2-3' of mono tied on with uni to uni knots will give you a weak link to break if you get hung up.
30lb braid with 20-25lb mono. The mono breaks every time.
In the long run, especially if you fish a lot and in heavy cover, it can be cheaper than mono.
Braid doesn't break down from UV as fast as mono. Doesn't get knicked up like mono either.
I'd cut off 5' of mono after it got kicked and retie after every fish. Do that every Saturday and a couple weekdays it adds up.
Mono after being stretched over and over again (big fish and snags) loses it's elasticity and weakens.
I have braid on my surf ABU 6600 for about 5 seasons now. 2 years ago I reversed it so the new end is on the outside and the old used line is down on the spool.
Try that with mono
The no stretch of braid makes for good hook sets.
Larger capacity allows you to use smaller reels.
If I do get wind (rhymes with bind) knots on my surf reels, fishing the in the dark... stuff happens...
I take what's left on them and use that for my casting reels and spool fresh braid on the surf reels.
The down sides to braid...
Since it doesn't stretch, you really have to work to keep your rod bent when fighting a fish. With mono and the massive amount of stretch that is has you can get sloppy when fighting a fish. Not so with braid. I've gone to softer/slower rods now for that reason.
St Croix Mojo for the beach and Berkley Shock Rods for LMB.
And most importantly...
Braid will cut you like a steak knife.
Once I was hung up and tried to break my line with a leather glove on.
Only took one turn around my hand, the line slipped and almost cut
thru the Wells-Lamont work glove.
Imagine a bare hand.
Now I take at least 5 turns or I use a piece of wood, stick or plier handle.
The best part about braid is the feel. You aren't guessing if you have a weed on your lure, you
know.
Quick jerk of the rod will snap the weeds off too.
No guessing about bites either.
Like the commercial said:
Try it.
You'll like it
