yes, you are correct. The Nickel bolstered knife will have a nickel frame. What exactly is verdigris? I thought it was just a toxic green tarnish that forms on copper and brass-based metals. I had no idea it would discolor the scales. Will, it not discolor wood scales?
I have decided that I will be ordering a custom buck hunter 110 with the elk handles soon and I am debating whether to get the brass or nickel bolsters.
Yeah, thanks. I think I will go with nickel bolsters now that I know the elk scales will stain from the verdigris. It likely is a problem with bone due to it being so porous compared to wood.Your description of verdigris is correct to the best of my knowledge. Personally, I've never seen it discolor wood scales but I've seen quite a few examples of discolored deer antler (stag). I'm only assuming that elk antler would absorb the verdigris in a similar manner.
It's your call, of course but I wanted to reiterate the risk that JD Bear mentioned above in case you hadn't considered it. If it were my knife I would opt for nickel bolsters hands down if the handle slabs are to be elk antler. I don't like verdigris infested slabs at all. I'd rather have the scratched up bolsters.
Lol I love lichen on trees. Kinda grew up around it though.I'm with you Railsplitter.
I don't think verdigris looks as bad on wood but it's still kinda ugly. It reminds me of lichen on trees...
Why wouldn't you recommend aluminum handles for barn use? I love the weight of the buck 110, and I am so used to it that I do not notice it anymore, but wouldn't aluminum have to be bulkier to be as strong? Similar to steel toe boots vs aluminum toe boots.
While I'll admit, these are really nice knives, and a couple are absolutely stunning, when this pic was posted the traditional forum moderators suddenly got a bad case of heartburn.- The ModsView attachment 1098943 I don’t think there is a lot of Nickel in the N/S bolsters. They are probably white brass like most U.S. coins. I like the Titanium handles for hard use, like the one in the lower left corner.
So is it a good idea to regularly polish my current brass 110 to keep the verdigris under control?
While I'll admit, these are really nice knives, and a couple are absolutely stunning, when this pic was posted the traditional forum moderators suddenly got a bad case of heartburn.View attachment 1099087- The Mods
not knock'n the blades, just say'n
My bad. I didn’t catch the traditional thing and let a pocket clip slip in there. They usually let 110’s go, but you must edit out the pocket clips and thumb studs.
GorgeousI like how brass looks next to horn on a 110. It's definitely work to keep it looking nice and shiny though, and the brass attracts dents much more easily than NS.
I like it too actually
I'm not really sure if polish would keep it at bay. I would guess maybe some mineral oil on the stag every once in a while would keep it healthy. I'm sure some of the other guys would know. It sounds like this will be on you every day all day so you might not run into that problem. In the past I never polished my brass or nickel bolster, but I've been doing it lately and I've liked it. I hope you enjoy whatever you decide on and use it a ton...
If one is worried about scratches or fingerprints on Buck's polished nickel bolsters, giving them a satin finish with a green Scotch-Brite pad works very well, and is easily done. Takes maybe 5 minutes to do it. I've done this with a Buck 111 of mine; it's especially good for concealing fingerprints from frequent handling. Can still be scratched, but the lighter scratches & scuffs don't stand out as much, as they will on a high-polish finish. And if they do get some light pocket scratches, the Scotch-Brite will fix it again very easily. Same could be done with brass, but it'll still tarnish more than the nickel will, on the Buck bolsters.
The 'nickel' of Buck's knives doesn't really discolor much at all, for what it's worth. Definitely doesn't 'yellow' like other variations of so-called 'nickel silver' will, which I've seen more on European or Germany-made knives in particular.
