- May 18, 2011
Hello everyone!!
I have started putting handles on pre-made puukko and Leukus from Puronvarsi and other makers such as Lauri, but all I have ever used is birch bark and small pieces of wood. I do not have the work space, tools or experience to make my own blades yet, so I would like to slowly hone my skills at making puukkos over time, one bit at a time.
-So far I have made a birch bark handle for a Puronvarsi 75mm,
-Working on a 230mm Puronvarsi Leuku with moose anter bolster/pommel, dyed maple burl handle with birch bark spacers
- Epoxying a Lauri blade with a coin bolster, antler spacer, dyed maple burl block and a spalted birch handle. Ill be shaping it tomorrow.
I have a handful of questions regarding the best methods to a few things that I would like to try, or at least find more information about.
I am not a fan of drilling out the wood and epoxying my blades in there with a hole that may or may not be tight. I had read in the past that, before heat treatment and after drilling a pilot hole, puukko makers (and some Japanese kitchen knife makers) would heat up the tang, or a rod, and burn a hole in the wood handle for a tight and perfect fit.
After seeing this masterpiece from centuries ago, I want to try my hand at doing this the traditional way. I also had a question or two about achieving certain effects and how to clean up after you burn the handle
https://imgur.com/a/0hsRLqc
1. Is it possible to do this by heating up the tang to burn the hole without ruining an already heat treated blade? I was told it could be done if you place a wet towel over the blade and part of the tang you dont want to heat up.
2. Have any one you made tang-shaped rods to burn holed for your hidden tang knives before? Ive seen people use file tangs, but none of mine are close to as small as the puukko tangs Im trying to burn holes for.
3. How far do you burn down the handle? I read that you should stop before you get the blade fully seated and tap it in the rest of the way if you aren't poking the tang out the other end. I was also told not to get the tang red hot, just enough to where it burns the wood so its a tighter fit.
4. Can you pull the blade out, buff off the burn mark and reinsert the blade?
5.Weathering wood: What would be the best way to (if it is possible) achieve the weathered look of that old burl without it cracking and shrinking too deep to compromise the woods integrity.
I am picking up some unstabilized burl from a friend of mine and was wondering if the old weathered effect shown in the example I showed above is possible. Could I burn the handle, oil the inside of the handle and possibly the ends (so it doesnt crack or shrink badly)and leave it outside this winter in hopes the UV rays, moisture and temperatures make it look that weathered?
Once weathered, id just soak it in oil for a few days so it does not continue to crack.
If anyone here can help me in my beginnings of puukko making, I would greatly appreciate it. I will have many more questions down the road, but I am theory crafting and getting ideas that I would like help materializing at this time.
Have a wonderful day!!
-DeadFall
-DeadFall
