- Dec 12, 2023
Is this legal in California? I believe this is spring assisted, but is very close to being a switchblade. What do you guys think?
TIA
TIA
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
That's not the issue. The issue is that you're able to open the knife without touching the blade via a mechanism in the handle (the separate flipper style actuator), that's what makes it a switchblade...not the assisted mechanism.Not sure how they can interpret the laws of switchblade covering everything of "assistance"
Thanks for the clarification. Going back to what WV said, so long as the blade is opened via blade itself and not a separate actuator then should be OK. I could be wrong as its been awhile since disassembled and normally run mine in manual mode but it is possible the actuator is a separate part. If this is the case then it can be removed entirely and then using the knife via thumbstud even with assist technology should be good to go. Again, no lawyer here but does seem logical.
