Right, but that isn't a proper way..Lots of people use the bottom of coffee cups. In theory there must be different “grits”. But I’m not sure.
Let us know how it works out for you.
What stone is it??Probably not, most likely ceramic is ceramic.View attachment 1393443View attachment 1393443
More info it helps, the guy is ceramic pot/vase maker. He told that his pieces are biscuit fired at 900 degree and then again at 1200 degrees.Well there are differences in ceramics. Most relevant here would be silica vs. alumina. But you also have to consider grit size and consistency, how brittle will that piece be, Will it clog up or shed grit, etc. I'm not sure if sharpening stones are sintered under pressure or not.
FortyTwoBlades have any thoughts?
let's doubt that her resulting finish is as smooth, homogeneous, dense, and mean-flat as a commercial ceramic benchstone.asked a ceramic potter to make a
Thanks for that info about the Smiths ceramic stone.6 years ago, Smith's was selling 6" x 1.5" ceramic stone for a couple of bucks (https://www.knifecenter.com/item/AC167/smiths-fine-ceramic-sharpening-stone-6). It was a subproduct from another industry, but Smith's offered it as a sharpening stone. It was ingenious! It was flat, uniform, fast. The dream has ended - the product was not replenishable. But it shows there is nothing special in ceramic stones such as Spyderco. All knife sharpening community is too small to create demand for a ceramic stone of super high quality that will be super cheap.
So how did you manipulate the ceramic's grit.View attachment 1395806
I probably picked up 6 or so of them when they were available.
They were actually very flat for the most part and I conditioned a couple of them with SiC grit to make them finer or more aggressive.
Although smaller they cut as well as the Spyderco ceramics.
These things were a smoking deal.
Did the ceramic pick up the actual grit size of the sillicon carbide stones? How long did they hold the same grit? Help me with the explanation of the process please..
Thanks, so if I put 1 micron diamond paste on 2 flat stones and lap them together long enough, they should become a 1 micron stone. Am I right?Sintered ceramics are fused grit, and have a file-like effect that's dependent on surface texture, so conditioning the surface with different grain sizes will produce different surface textures that will impact how coarse or fine the stone behaves.
