I'm not sure the DF2 is really any smaller when it's closed than the Chap. It's certainly smaller overall when opened, but the handles are just about the same length, making them similar in size when closed.
The more I think about it, the more clear the answer becomes. Both. Get both. They both are awesome. Get both.
the df2 is smaller and lighter and cheaper
There i was curious and found this pic
I vote for DF2 since the back-lock is so damn hard to operate on the Chap.
It's easy to adjust the pressure by moving the spring toward the lock bar pivot a little bit. See my pic above. The spring has been relocated, the lock bar is much easier to depress, and the knife still locks up tight. You don't even have to take the knife completely apart. Just remove the scale and liner, lift the spring from under the lock bar, slide out of the notch in the backspacer a little, and put it back in position under the lock bar. Put the liner and scale back on and your done. Took me less than 10 min and I did more than I described above.
