Welcome. Good news, for $150 you will avoid most of the self-destructing type bali's on the market; where the pivot pins will break, or the handles will fall apart. Almost the entire BM 4x Titanium line can be had in that price range, and they offer adjustable pivot screws when the handles gets a bit loose. Those titanium handles so far has not been reported to shatter or break under normal use. Besides, if it does break, they have an excellent warranty program.
If robustness is a true consideration, you might also want to take a look at the Roton Monarch. Availability is a bit sketchy, but it's built tough with solid milled Stainless Steel handles, and a 3/16" tang pin.
I would recommend the Brass SWAT, but I personally think the blade is a bit too brittle to withstand repeated drops to the ground.
