You can make anything work, and it’s not like a tanto won’t cut. A blade is a blade at the end of the day.Despite the negative press about food prep, I maintain that the tanto makes a first rate steak knife.
I love my large tanto Inkosi, the grind style is fantasticThe hollow grind is the same across the Sebenza blade shapes. The tanto will have the least blade height, if that matters to you. It also stays quite consistent in behind the edge thickness along the main edge, whereas the drop point thickens up noticeably. Even the insingo gets slightly thicker toward the tip.
I'd say the tantos are the least popular, but I enjoy mine thoroughly. If it speaks to you, I can't think of any measurement or specification that should stop you from getting it.
