You don't need anything super fancy. If you can turn your speed down a squirt bottle with some soapy water is what I use and it works great. If you are running fast you will need something more but I have seen where guys work out hanging a bottle that drips onto a sponge that just lightly contacts the belt. A little soap helps to wet out the belt and not to just get flung off.Got it. Thank you all. Looks like along with that 2x72 grinder I need to set up a water system to grind cooler on thin hardened stock....
When I first started grinding I made about 20 blade blanks with mild steel. I didn't attempt to use the "good" steel until I was comfortable with my machine.
Lol. It was the smartest decision I ever made in my life. Lol.I am impressed
Good idea. Did not even occur to meWhen I first started grinding I made about 20 blade blanks with mild steel. I didn't attempt to use the "good" steel until I was comfortable with my machine.
Sorry .. that was way back in the original post. By “thin” i am referring to 0.08” stockWait, what do we mean by "thin" stock?
Agreed! In a little bit i am going to add something more to this thread: i think the Japanese makers “cheat” somewhat- giving a finished product that “looks” like a really clean bevel line - where in reality it is NOT. will post pictures and dscribe when i can...Ah, maybe I should have checked the rest of the thread.
I'm definitely on board with the thinner is better policy for cooking knives!
Normal ceramic belts on only go to 120 on a X or Y weight backing. Going finer is not using belts in the sub 40 class. Using a 60 should be less aggressive and once you get close bring it in with a 80. Grinding after heat treatment will also help a lot. I find that it is more consistent than grinding soft. Sometimes I find that the belt will sometimes sorta catch and dig on a soft blade.Slight resurrection of this thread. My grinder is in! For grinding bevels, i seem to recall people saying start with a less aggressive belt ... but Avigil just posted saying he does the entire bevel at first with 60grit. I just got in some ceramic 140 grit. Should i be thinking more like 60 or 80? Again, this us rather thin stock ... and mistakes happen slower on finer grained belts, right?
I dont follow what you mean by "going finer is not using belts in the sub 40 class " ????Normal ceramic belts on only go to 120 on a X or Y weight backing. Going finer is not using belts in the sub 40 class.
