- Jun 17, 2012
What's your favorite way to clean soot off your pots after you get home from camping? So far I have been using Dawn dish soap and 000 steel wool.
What's your favorite way?
I tell the kids
If you clean the pots , you get a chocolate
works a treat
S.O.S pads after a good soak in hot soapy water.
Firstly, if cooking on coal or flame, first coat the OUTSIDE of your non-cast iron pots and skillets with the dish soap. Clean up will be much easier as it's that layer of soap (and not the pot) the soot adheres to. Every Boy Scout knows this trick, or at least he should.
Secondly, if there is something else stubborn you must absolutely remove, make a paste of baking soda and water. Cover the spot with the backing soda and water paste, leave it on for twenty minutes or so, then scrub and rinse.
Baking soda, water, and vinegar creates carbonic acid which breaks down making "scrubbing bubbles" --- good for lodged drains, sieves, and such.
Baking soda and vinegar are really the only household scrubbing cleansers you'll truly need for most applications. Sometimes you use them alone. Sometimes combined. Depends on application/use. Saves a ton of money too.
I try and clean them up while I am in the field. Sand has become one of my preferred methods. When I am sea kayaking there is plenty of sand around so I just scrub the pot with handfuls of the stuff or rub the pot into the beach. I often use sand in freshwater streams too when I am hiking.
I have a bit of concern with using sand though. For example if I had aluminum pots, I don't think I'd want to scrub with sand because I'd be afraid small particles of aluminum might break off and pose a health threat if I were to ingest it the next time the pot was used. In fact, I don't know if I would want to take steel wool to an aluminum pot either. I am somewhat concerned with stainless steel too since it's an alloy. Not sure if my concerns are warranted or not and I am definitely not an expert on this stuff.
It is a PITA to have to bag your pots to keep the soot off of other gear. I wash mine down with Dawn between trips and several times a year strip them down with FastOrange mechanic's hand cleaner.
