- May 21, 2000
French Press simple and the best. It doesn't need to be complicated.
+1
This method produces the best coffee I have beer had. It's also very inexpensive and easy to clean.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I'm an average coffee drinker and the lowest end Keurig is enough for my wife and I. A quick cup and variety of flavors makes it worth the price (even though they are over priced).
Yeah, but how's the taste of that?Im a Keurig user, im a fan of the speed of the brew. Plus they make so many different flavors so each cup can be different.
I'm kinda looking for a new one too, something like a Mr Coffee drip maker but with an insulated pot instead of a burner that keeps 'cooking' the coffee.
We have the Krueger coffee makers at work. I don't recommend; a PITA, price per cup is very expensive, and the coffee from pods doesn't taste as good as fresh ground.
I use straight tap water. Our chlorine levels are so low and the tap water here tastes great (cold water lakes at high elevation). I've stayed other places, hotels, where the tap water sucks and as a result the coffee sucks.
Don't use distilled water, bottled if anything other than tap water. Chlorine and chloramine will evaporate out over several hours, so often if you prep the maker before bed and set the timer the water will change flavor for the better.
My parents have one that does not have a carafe but more like a holding tank it brews into, then just put your cup under the spout and push the button. I'll have to look at it next time I'm there. I had one with an insulated carafe and it was a pain to clean, the opening was too small to get your hand and scrubber into. Even my miniature wife couldn't get her hand in it. It sure kept the coffee hot well, but after a while the build up and staining inside started to affect the flavor.
-Xander
Can you make it taste like a Starbucks Cappuccino?
I bought one of these moons ago for everyday coffee on the run use, liked the no burnt coffee feature so well, I bought a second one as a back up. This model is only a 10 cup BTW.
It could be years until I start using the back up coffee maker though. I took this one apart after it started to slow down after many years of use, vinegar didn't help, so I took it apart, took out the ball and cage in line check valve from the inside of what looks like high temperature hose and now it runs like new.
Check 95% of the places you eat out at and you will find Bunn Coffee Machines ~~ wonder why.??
If you can afford a second coffee maker, try an Italian moka pot.
