Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
...the proper technique?
i have one of these, quality control wasnt the best on these, my weld's spotty and the eye's upside down. might have been re welded but thanks for IDing itIt's an older model. Newer ones had the eye welded on. Yours also a square-head bolt which indicates age. Yours is cool for the forge weld alone.
The thing is there is just no value in these. Nobody wants them. I've kept and restored one because it had a railroad stamp on it and I collect from that railroad. Yesterday I came across a very nice True Temper brush axe at an estate sale. Like new for $10. I almost passed but decided the handle was worth $10 to me.
...from a USDA booklet titled "Equipment for Clearing Brush from Land" published in 1961:
Brush hooks.-- Brush hooks are useful in cutting the stems of growth. The brush hook is swung like a scythe. It is sharpened by grinding with an abrasive wheel.
Machetes are mentioned for cutting "stems or branches", but the brush hooks are said to be for stems (not branches). This is written in the section on "Small Brush", defined as woody growth having stems no larger than 2" diameter.
Farmer's Bulletin No. 2180, Equipment for Clearing Brush from Land, USDA, 1961
from this thread on Brush Axes:
http://www.bladeforums.com/forums/showthread.php/1239807-Brush-Axes
[Note: My less-than-literal interpretation of that brief "swung like a scythe" instruction is that the brush hook should cut low, at stems near to the ground, and not be swung overhead at branches.]
I've found in particular that there's a particular method of gripping the handle that works best, allowing one to immediately and neatly turn the wrists to reverse the blade such as to cut on the return stroke. It's almost a sweeping action side to side. There are other strokes one can use for cutting undergrowth where you fish the hook behind a stem nearly parallel to the ground and then just draw the tool back towards yourself with a quick jerk to sever the stalk low to the ground, etc. but the bulk of the work is performed well with the aforementioned method.
His brush axe is sharpened on the outside of the curve, maybe the inside,too. That style was common but not as common as yours.
I have a mostly unused brush hook similar to this which was given to me by the original owner who'd bought it in the mid 1960s. The blade is unmarked but the Walters stamped handle does have a kerf cut in it.Agreed. The original haft wouldn't have had the kerf. But it's old. Slim, nice unclipped fawns foot.
FWIW, the replacement handle (70-011) for Council Tools 12" single edge bush hook (122-C) is the same as the one for their 3.5# Jersey (35JR36C).I have a mostly unused brush hook similar to this which was given to me by the original owner who'd bought it in the mid 1960s. The blade is unmarked but the Walters stamped handle does have a kerf cut in it.
The gentleman has two left hands (or is all thumbs) when it comes to repairing things. He was a recent PhD mining geology graduate when he bought this (plus a Montreal pattern pulpwood Walters) in the 1960s figuring it might be handy for exploration field work. He said the thing scared him enough after trying to use it that he put it away and never used it again. Only reason I got it (his wife discovered it while cleaning out the garage 25 years ago) was I have been replacing rake, shovel and wheelbarrow handles etc for him for a long time.Did he state that he had never re-hung it?
You'd have thought the factory would take the time to stuff a shim in the kerf (for appearance sake) before assembly. but I guess it wasn't high priority nor did buyers care.Thanks 300. I guess axe handles in new brush axes are more common than I thought. Several folks have seen them.
