A few years ago I made a knife from O1 tool steel. I heat treated it in the BBQ, quenched it in canola oil when it was ready and tempered it in the oven at about 220 deg Celsius (approx 430 deg Fahrenheit) for an hour twice if I can remember correctly. Of course this heat treating method is not going to be great and is not precise, but I'm just giving some background information
The thing is that's baffling me is that the edge rolls when cutting up veggies such as onions, carrots and potatoes, yet doesn't roll when I cut up chickens, going through the cartilage, breast bone and rib bones, nor when I use it on wood or purposefully whack it into the plastic chopping board or laminated kitchen counter top (did it to see if the edge would roll). I've edge tested the section of the blade that rolls by cutting sisal rope and cardboard until it no longer slices paper and got about 120 cuts on the rope and 130 feet of cardboard, which is in line with how O1 should perform apparently. No edge damage was noticed after testing it on the rope and cardboard, it just lost its paper slicing ability but still had an OK working edge on it. So according to the edge tests, the heat treatment went OK, but why does the edge roll when chopping up veggies? The veggies are clean and have no dirt on them when cut so that can't be it. I've whacked it into the plastic chopping board much harder than the force using to slice veggies with no edge rolling, so the chopping board isn't the culprit either.
I should note that it is dead easy to get a razor edge on it using stones and steels back to a razor sharp edge quickly after rolling, but it doesn't really feel gummy on the stones.
It's very confusing...
