There is no commercial convex sharpening system. However, you can easily put a V-edge on a convex edge if that is more convenient for you.
Bark River has a good tutorial for sharpening convex edges here:
http://www.barkriverknives.com/convex.htm
Wet/dry sandpaper works best; I start with 200 grit and go to 400, 800, 1000, 1500, and finally 2000; and follow with a loaded strop. You can get +1000 grit sandpaper from auto-supply stores.
The idea behind the mousepad is to use a surface that has some degree of "give". I've read where some people use phone books as well. You don't want a medium that is too soft as it will round off your edges. Same idea as far as pressure on the edge, you don't want to press too hard or else you'll round the edge.
A good technique is to use a black sharpie on the edge, and then make a few swipes on sandpaper. When examining the edge, you can see where you are wearing away the marker. If you are holding the spine too low, you will remove ink from the shoulders and not the edge (a common mistake).
Maintaining a constant angle is the trick to all sharpening, although free-hand convex edges are a little more forgiving than free-hand v-edges.
Most of all, have fun!
