Coping blade question
While looking through my copy of Remington Knives Past and Present I saw something that has me curious. On the page illustrating the different blade types it shows a short wharncliffe with a saber grind and labeled it as a coping blade. It describes what we all call a coping blade as a cut off pen. Did Remington use different terminology than everyone else or did the name of the blade change over the years?
Thanks,
Jeremy
Coping blade (Spear Main)....
The 1946 Camillus catalog gets it right.
I don't know if it is "right", but I agree that the Camillus definitions match my understanding of such things.
It kind of is not an exact science, though.
I don't have any insight on the coping blade conundrum, but I did want to point out that the spey blade that they're showing is awfully pointy. It looks more like a drop point to me than a spey, or a very slightly clipped clip blade. I wonder what the reasoning for that blade shape is as it wouldn't serve the purpose of being a blade without a sharp point, which is what I've come to accept as the definition of a spey blade.
Thanks for the replies. I suspect if Camillus was calling it a coping blade in 1946 that Remington was just being different.
Cory I agree about the spey . The one in the picture is shaped a lot like the one GEC puts on the calf ropers. When I got mine I remember thinking it was awfully pointy.
Coping (in carpentry) is fitting one piece of wood to another. Usually it involves mouldings, so for instance fitting a cove moulding to another at 90 degrees. You can scribe it, cut it with a coping saw, then refine the fit with a little paring with a coping blade.
I learned to do it that way, but the art is largely lost. Consequently the term is prone to being confused/mis-understood.
I can see the Remington blade (pictured a few posts back) being useful, as well as the cut-off pen. But there is a properly named coping blade in existence as well! And when it comes to naming them, I hate the way makers and purveyors use questionable names for knife patterns and blades!
'Cut-off pen' is a name I have heard old Sheffield cutlers use, and I think that pattern may have even earlier names. I'm with you on the 'questionable names' Charlie, and it seems that once a manufacturer gives a blade or pattern a new name (sometimes the wrong name), it quickly gets adopted. Plenty of businesses don't seem to be able to tell the difference even between basic blade-shapes like Wharncliffe, Sheepsfoot, and Lambsfoot, and are happy to mix-up traditional patterns and misname them, so the confusion among users is hardly surprising.
Cut Off Pen =COPing
Well played :thumbup::thumbup:
Not by everyone :D
Pete
Thanks for the very informative post, Charlie. :thumbup::thumbup: I had always assumed that a coping blade on a knife was somehow related to a coping saw, but I didn't know how. Now I think I do!
My next question is whether either the coping blade or coping saw is related to my attempts at coping with misinformation. :D:D
- GT
You guys are funny ;)
That coping blade is certainly a very useful day to day blade to have at hand,
Eureka_coping.jpg~original
G2
Nice to see you coping so well, Pete!
Nice blade to cope with also, Gary!
:thumbup:
Often the shape of a Sheepsfoot and Coping are the same shape
The sheepsfoot is bigger and the coping is finer
Often you will find a coping blade on the two back small blades of a split spring whittler
I am showing on a Queen Whittler with a split spring
And a S&M Horticultural knife
I too when working as a finish carpenter used a coping saw and a coping blade.
Now a days the plastic utility knife with the breakable blades has taken the place of the coping blade of a penknife
It can act as a cutting tool also as a fine marking tool
Thanks for the informative posts thus far guys...I do learn something new everyday!
I'm not a historian of blades or patterns but for the finish carpenters above, is the presence of a coping blade what defines a carpenters whittler???? I use coping and other zero-belly blades to score my projects instead of using a pencil. But I'm by no means a pro. I watched my Dad use a miter box and coping saw to install crown molding in a bay window bumpout in a post-Victorian house. How he managed those compound miter and back cuts had me scratching the old noggin'.
I think a carpenter's whittler refers to a larger whittler, usually closer to 4" closed, than the more common balloon whittler at 3½".
