I had some experince with CPM20cv in the past and i have to say its a good tough steel but here's my question. there's charts on the web that 20cv has the same impact toughness with 440c. but how about flex toughness? Esee knives states that 440c from their testing will break at around 10-12 degrees if flexed. with the CPM process, will a 20cv suffer the same consequences when flexed? i would probably never to this to my knives but i'm just curious.
I would add that ESEE claims the following:
http://www.eseeknives.com/warranty.htm
ESEE KNIVES ARE NOT THROWING KNIVES! They are hardened to a higher Rockwell than throwing knives and will most likely break if thrown, possibly harming the user. So, do yourself and your ESEE knife a favor and DO NOT throw it. Using any knife not meant to be thrown as a throwing knife is idiotic! We would rather idiots not buy our knives.
ESEE 1095 from Rowen is HT'd to 55-57Rc,
soft for a knife blade, and it is their only products to which their "no questions asked" warranty applies. They assert that
any knife as hard or harder than theirs will break when thrown, and anyone who thinks otherwise is an idiot... Wow. Then they state:
We do not warranty our 440C Stainless Steel knives from abuse.
Compare that to Entrek Knives which uses 440C exclusively:
http://www.ennis-entrekusa.com/About Entrek USA.htm
If this Entrek USA knife fails for any reason it will be repaired or replaced at the option of Entrek USA at no cost to the original owner. To date we have replaced four knives in 12 years, all were damaged while being used for other than their designed purpose.
While I am interested in the ESEE Gibson and love the Izula, I generally avoid their products due to such lack of confidence on the part of the owners. *shrug*
To date I have not seen a broken S!K and only heard of one that broke in the skeletonized handles (per Ellie/Guy). The PM process should reduce/eliminate the carbide aggregation for which 440C is known and which contributes to low fracture toughness. As stated above, if you find yourself over-flexing the blade, it's probably best to stop and reset before risking microfractures regardless of how unlikely they are, because a flexing blade indicates inefficient prying - try again at another spot. Most S!K models are thick enough that such flexing would be minimal without use of a cheater-bar.
In any case, how tough is 20CV? I haven't tried it personally, but Guy's demonstrations of M390 and S90V (similar if not higher carbide loads) are telling:
(Skip to 11:00 is the video doesn't do so itself)
[video=youtube_share;JnAKtElk_PY]http://youtu.be/JnAKtElk_PY?t=10m59s[/video]
[video=youtube;gFzI9U64bjg]https://www.youtube.com/watch?v=gFzI9U64bjg[/video]
