FredyCro
Basic Member
- Jan 11, 2019
Is that a pic after straightening? The rest of the warp you ground out?I also use an anvil, and get better results now compared to when I used a piece of mild steel ,that was a bit off in the surface too. You can get a new 20 kg Kanca anvil on amazon.de for good money. It's what I have.
I use a fairly rounded carbide tip, stuck in a hammer. I never hammer hard, just tap, and the divots are shallow and sand out easily. This is 2 mm 14c28n at 61 hrc on its way to a flat grind. You can see the divots in 2nd pic.
Yeah, those divots look much less stress inducing then the ones I did with the drill bit.
