The other thing to consider is that if you use the blade for pocket carry, if you reprofile the blade (it's take forever), and to a small extent eben if you sharpen from both sides, you will move the bevel of the edge away from the frame, so you can potentially cut yourself, clothing, or objects that are in your pocket along with the blade. May cause real damage, or at the very least be annoying.
