Assuming any retained austenite will be transformed to martensite, I hope the non-steel materials can survive the temper you'll need to destress your knives. Otherwise, the cryo won't be your pal.
As far as stabilization of Austenite, it is certainly possible to quench and then cryo, and provide a virtually "seamless" cooling from Austenizing temperature to minus 320F.
I have also observed firsthand the effects of cold on A2 blades that were overheated during HT, allowed to rest for several days, the placed in an ordinary household refridgerator. Ths result-An increase of 4 points Rc hardness.
Is the temperature of a mere refrigerator or freezer enough to do any good?
What is the lowest Mf of knife steels?
Do you get the same result sticking a blade in a fridge over night, or just leaving it on the bench til next year to finish it?
I'd have to say the austenite is stabilizing a little slower than immediately.
gah, someone just explain this to me...
Well I followed the Landes recommended heat treatment recently with a 350F temper and got 61 Rc (using a 1925F austenitizing temperature).It is alloy dependent, AEB-L is a really low alloy steel and you can get very close to full martensite even with low tempers. According to Landes you can get 67 HRC, with the biggest problems being improper heating (rate), delays in quenching, lack of oil, wait before cold, lack of repeated cold/temper etc. .
Well I always thought sticking a blade in a dewar full of LN was pretty ghetto, but I appreciate the offer.Larrin you better send that blade to me for the backyard cryo treatment.
Therefore, AEB-L quenched in Germany needs less retained austenite to get that AUS feeling, but AEB-L in America needs more.
Well I always thought sticking a blade in a dewar full of LN was pretty ghetto.....
from the knifemaker forum...
