We have two types of Cryo treatment.
1. LN at approx. -100 to -120 degrees F, this has been used for many years in the bearing industry for retained Austenite transformation to Martensite. This is normally done in an insulated box with slow lowering of temp., not a dunk in dry ice and acetone or other thermal shock treatments.
2. Deep Cryo at -300 degrees F, this is where the mystery transformations happen. Precision target rifle barrels will show 3x life before accuracy falls off, racing car engine parts last much longer, brass musical instruments change sound, razor blades last significantly longer, womens nyloy stockings are much tougher and resist tearing.
This process is also not a dunk it in the LN,,,,it is a 8-12 hours slow reduction in temp,,,,hold at -300F and a slow rise to room temp. The total cycle is 24 to 36 hours. Heat treated steels are then raised to a tempering temperature similar to the original heat treatment.
Many idividuals continue to debunk the -300F cryo however, the main research testing published is from the Soviet Union days and is not generally available to the public.
Try the Cryo and test it for yourself,,,,do not read papers and quote others opinions or theory. My rifle barrels of 416 stainless and 4140 steel showed a greatly increased life compared to factory production, my deep cryo treated woodworking plane blades (A2 steel) will stay sharper much longer than A2 without deep cryo.
Regards.
FK
