No it doesn't look like that. There's little spots no bigger than a sesame seed. Most come right off with a little bit of grinding, but these knives are already very thin so there's no room to remove much metal without affecting the geometry. But if you don't grind them all the way out, some of them leave a little micro pit behind that shows.
Some knives don't have it at all. Others have it very minimally, but there's enough that have significant spotting that we're probably going to lose over half the batch and we made fewer than 100 total, there were never going to be very many. We always get some losses, but I thought for sure I'd made enough to cover the pre-order, I've never had scrap this bad.
It has only affected the DEK3. No hint of a problem on the DEK1 and they were heat treated side by side at the same time. I think this is because it is a different melt of Magna cut than the two melts that I did my development work on which includes the melt we made the DEK1 from.
I'm certain we will be unable to salvage a bunch of these. But they won't be a total loss. Ben can use them to practice sharpening before they go into the creek.
If they are still good functional knives I might surface grind my maker's Mark off of them and find something to do with them.
