- Mar 8, 2008
Still using the first side of the original blade that came with this box cutter I've been using for years.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Interesting. All the reviews and expert opinions of a stockman that I've read seem to say that the sheepsfoot is for the hard cutting, and saves the pen knife blade for fine cutting. I'm just the opposite with the sheepsfoot. I thin mine out as well, and use it for the fine cutting, I think it's the most precise and easy to handle of the three.I use a DMT DiaFold (usually a Fine 600) to resharpen utility blades. I have a whole bunch of replacement blades on hand. But I may never use them all, simply because I keep resharpening the one in the handle. I don't often use the utility knife anyway, as most of the box-cutting I do is with the sheepfoot blade in my Case 6375 CV stockman. VERY thin grind on that blade, and I've thinned the edge even more. I've become spoiled for using that blade on cardboard.
I use the sheepfoot probably 90% of the time, over the other two blades in my '75 stockman. Mostly for cardboard & package-opening tasks. And in some of the hobby woodworking stuff I do, it's a great scribe line marker and fine-tip 'scalpel' for trimming the visible ends of double-stick tape I sometimes use to hold pieces together for precise cutting alignment and screwing down. AND, the thin & pointy tip does a great job lifting the cut ends of the tape for removal, which is otherwise tedious trying to do with the fingernails. Works beautifully for that.Interesting. All the reviews and expert opinions of a stockman that I've read seem to say that the sheepsfoot is for the hard cutting, and saves the pen knife blade for fine cutting. I'm just the opposite with the sheepsfoot. I thin mine out as well, and use it for the fine cutting, I think it's the most precise and easy to handle of the three.
Yep, time is money. I was schooled years ago by an old drywaller that straightened me out when I needed to change my blade. Sharpen both ends of your carpenters pencil etc....I've found I get the most aggressive slicing edges on my box cutter blades by touching them up on an American Mutt bench stone or pocket stone. A quick scrubbing action on both sides gets a worn blade back in action in a matter of seconds, and takes less time than swapping it out for a fresh blade in most cases, even with models that make blade exchanging quite rapid.
It even flips the blade automatically to sharpen both sides. That's pretty cool.this looks interesting enough:
automatic utility blade grinder
